Jason Thompson
Registered Member
- Joined
- Nov 22, 2017
- Posts
- 17
- Reaction score
- 3
On my 81 Blazer I noticed it has different size differentials the front is 10 bolt and rear is 12 bolt. So is that a bad idea? I also need to pull the cover to find out ratio. No RPO in glove box and no tag or imprint that I can see. I rarely take off road and if I do it would only be for light 4 wheeling, however, I still frequent the freeways. The reason I ask is I'm planning on making sure the gears are 373 or 411. It has a 400 sbc with 700r4 and 35" tires on 4" lift. My second question is how difficult is it to change gears and does the front and rear need to match (in terms of 10 or 12 bolt)? Thanks for help.
