81 One Ton
kgblazerfive
keymaster
Hooper, Utah 84315
Selling my one ton runs good no issues just put a new battery in it
has a big block and runs on propane. If it doesn't sell going to part it out. Pictures are old, seats have more wear and the paint probably has faded a bit.
$1500
Thought I would put this back up. Looking for something to be able to tow my burb and still get decent gas mileage and do 70 while doing it.
Interior is red and the A/C does work well it worked this summer can't really tell now cuz its like 20 out side. Its a th400 so that would be an automatic.
Bump
Still for sale has new water pump in it now and a full tank of propane and a modded hose from the reservoir to the PS pump they don't make them any more had to get one custom built
Decided to buy a Dodge diesel and bite the bullet. I have a 32 travel trailer to tow around.
So I won't be needed this, $1500 is the lowest its going, I will part it if it doesn't sell cuz the motor and trans will fit into my Nova, and the tires will fit the Dodge I'm going to buy.
can I see some side shots and back shots ?
hows the rust ?
how many miles on it ?
any problems with it to be able to drive it to Virginia ?
And it runs on either propane or gas correct ?
Not sure of the miles odometer says 96 thousand pretty sure it needs a one in front of it
Yes it runs on either gas or propane, propane tank is empty right now so it just runs on gas.
The only problem with driving it to VA would be the gas it would take, or propane
I will get some current pictures
