Lol. You guys have a mobile lift but not a tall trans jack?
Other then some core support work, we don’t do major mechanical work. The work I do on mine is the biggest mechanical work being done at the shop.
It’s always had a 3 bolt converterWhy do you have a 3-bolt torque converter?![]()
It’s always had a 3 bolt converter![]()
Stock 6.x diesel torque converters have 6 bolts (and a lower stall speed than their gas counterparts). I'm guessing yours is aftermarket given the sticker on the front surface.
So it’s pull the stepside out and push the Dodge in. Making some progress.
Got good insurance?So slight update. The trans shop has to pull the trans out to fix the issue. So the old girl is waiting her turn. Small place they only have two lifts.
The dodge I need to get inside to reinstall the harness I had fixed. But I’ve been doing a lot of thinking about the trucks future. I’m in a few 3rd gen dodge pages on FB and there have been a decent amount of trucks that have burned down. Just like a fellow brothers truck did. And it has me fairly worried.
This isn’t the first electrial issue have had with the truck and I don’t see it being the last either sadly. It sucks because the engine runs great, trans is recently rebuilt so it’s good. I’m just legit scared the truck is gonna short out and burn down on me.
Now you’re probably thinking “well trade it in for a brand new one, problem solved.” Eh, not so much. I’m hoping/planning to buy a house this year. So a brand new truck isn’t in the cards for a while. Sure I could sell it for some econo-box to save miles on the stepside(which I’ll be buried in) but still a big hit to my credit.
Course then I get crazy thoughts like buying an old crewcab and swapping the engine and trans from it. With a new standalone harness that would solve my wiring fears. But I barely have time for the two projects both trucks currently are. Never mind once I get a house.
And now I’m rambling![]()
Full coverage on the dodge.Got good insurance?
Don’t park inside.
Battery disconnect.
Drive it.
.Ok so I got the truck back last Wednesday and I've been driving to and from since. Other then fixing some small things they did. Like putting the crossmember in spun 180. The old girl has been running well enough.
Today I had to stay a little to fix the linkage coming off the latch for the outside drivers door handle. Not tragic and a relatively easy fix.
When I went to leave and lock up the shop I hD the truck running and the lights on since it's dark. And this was what I saw.
View attachment 402594View attachment 402595View attachment 402596
I'm thinking bad ground or bad lamp. Being the bottom its just the high beam and as shown the low beams are on.
They had been working fine, so this is a relatively new issue. All new headlights wouldn't hurt of course. Might be a good time to upgrade to leds.
Check your grounds for sure, same issue on mine....
New lights won't solve a ground issue. But it's a good excuse, if you were wanting one...![]()
. So gotta fix that to now.
