Love the truck. Glad you decided to stick with the 6.5. Though I have been around the 6.X trucks my whole life, I’ve only really just started to dig into the one I have now. Learning quite a bit. They’re not a fan favorite, but they’re simple and easy to work on.
Also nice to see another Florida guy on here, and you’re not too far either! My brother lives in your area. I picked up my K5 tire carrier from a guy in New Smyrna Beach.
I did the exact same thing in the exact same passenger side corner on my 6.5. I’ve yet to fix it. It’s a pretty minimal leak. I had to do the driver side over twice, learning the hard way, and just haven’t had the time to tackle the passenger side again, or the motivation, since it’s so small a leak.
Good luck with the rebuild of the 6.5. Glad you started a build thread on the truck!
Andy
So today I got the downpipe installed. I have a header wrap kit and I'm debating using on the downpipe as it sits pretty close to some wires and hoses.View attachment 278018
It's easy enough to remove that I probably will after I do some test driving. I still need to replace the wastegate actuator and run the boost reference hose.
So I fired her up and kick in the fast idle. She warmed up pretty quick to click it off but it is 90° today. She had a nice haze while idling but the oil from assembly does have to burn off yet. I didn't hear and strange noises so I think she's going to be a good runner.
SHE MOVED!!!!! All of 2 feet. After I shut her off I noticed two areas of concern. First the fitting I brazed on the turbo oil supply is weeping a bit. So I need to touch the up. Then I noticed the second leak, right at the rear most corner of the passenger valve cover. I guess I missed a small spot when I put the rtv on when I installed them.
So this is how day ended.View attachment 278029
The worst thing about the 6.x engines is the injector lines going over the valve covers. In order to do it right you have to pull the intake and the lines on the problem side. It really sucks but I want it to last so oh well.
I hoping to get it done tomorrow.
Andy
