'83 208 rear stock driveshaft
racercrazy
O\' Fallon, MO 63366
\'83 208 rear stock driveshaft
I need a slip yoke driveshaft for an 83 manual/208 10 bolt blazer. The drive shaft I'm needing uses the u-joint with the bigger caps (if that makes any sence). Please help me out.
thanks.
Re: \'83 208 rear stock driveshaft
got one
30 + ride /forums/images/graemlins/deal.gif
I have the stock drivehaft out of my 82 350/208 setup. Minus the slipyoke portion. Let me know if you need it.
Blake
Yeah, it looks like its going to work out in my favor. But I do need to get it out of his way and put it some where else for the time being. More than likely it's going to be a winter project. Still have to do a couple of things to the 89 first. I need the drive shaft to move the 83 safely.
the shaft i have is outta 83k5 with 700r4 and 208 pm me if you want it
comes with the slip yoke too
/forums/images/graemlins/waytogo.gif
The shafts out of manual transmission rigs use the larger 1350 ujoints. Only a shaft from a manual truck will work for the joints and posibley because of length too.
Harley
Thats what I was talking about with the bigger caps, the 1350 u-joints. I just couldn't remember what they were called right then and there. Thanks Hossbaby50.
i have one from a 465/208 10 bolt rear it has the 1350 u joint in the back for the bigger yoke that the manual trans blazers had hows 30.00 plus shipping sound its a good shaft with good joints . i went to a fixed yoke so i dont need it any more
Kevin
