'83 K10 SB "L1TSBFIBBC" build
Thank you, however, I like your build threads! I wouldn't be ashamed of anything if I were you.
Reading the last couple post about the dirt drags 2 years ago reminds me I did the same thing about a month ago. Took it to the dirt drags and had a blast. After I won the gas class I raced one of the SxS class with a RZR XP Pro Turbo cranked up over 28 lbs of boost, it was really close but I beat him, and then beat him again after that, was fun(he wanted a rematch). Then right when I went to race the diesels again they shut it down because it was too late. I also got a good view of my truck on the dirt launch and saw how awful my axle wrap was in the back. I need to fix that. I'll try to add a couple videos soon, didn't get all the runs on video but got a couple. Took it to the sand dunes in July and beat the snot out of before that, nothing on video there, too busy having fun in it.
Nice Heath. I feel the same way. I barely get any video anymore, just having so much fun to stop and setup video. I did get one video but its not all that impressive.
So its been a while since I posted about this, last year was a bust between the tracks being closed and my tires being not sticky enough after 3 years, I didn't even go with the Regal. I did race my fathers 36 Ford Pickup with a BBC behind the cab. But this year I got what I have needed since I redid my whole car, double beadlocks. I was waiting for them from the wheel company, so I missed the spring racing, but I got back out this October again.
The first time I took the Regal out with the new tires, old wheels and the new drivetrain 4 yearsd ago, I spun the tire halfway around the rim just trying to tune it on the street! So I called M/T and they said either double beadlocks, or glue them on. So I glued them on. You aren't supposed to rim screw radials for safety reasons. I think that worked temporarily and then started slipping again, but I am not sure. I can tell you this, new tires and double beadlocks gave me better 60 foots than I ever had.
And I put 3 junior dragster harnesses in the back so I could take the whole family to ice cream, or pickup from school, etc. The kids love the cam locks, and I actually get compliments on the rear harnesses for the kids, I didn't think people would notice. They are old enough now even the youngest is up to a booster, so the 4 point harnesses made sense. I don't trust the lap belts only with the cage bar right behind the front seats.
I also installed four 3" stainless Borla mufflers in parallel with some custom made Y pipes I fabbed from the dual 5" oval exhaust I had made previously. It quieted it down quite a bit vs the 5" oval mufflers with almost no case volume I had before. So I have one pair of these on each bank, each side is dual 3", so quad 3" exhaust, ha ha
So the first pass I went down the track for a new best all motor. 9.58@142 with a mild 1.41 60 ft through the mufflers. With my heavy car, 3.60 gear, and 4L80 trans it’s not really setup for 60 ft on motor. I keep the front end travel low and the shock rebound somewhat stiff so I don't wheelie. My shocks are double adjustable front and rear, which is critical when trying to tune a drag car launch.
Next pass I warmed the bottle and turned on the juice preparing for an 8 second attempt. The tires had warmed up to about 18 psi from 17, I let it go thinking with the wider 9" rim it would be OK since it had not spun at all, before I only had 8" wide rims. I was wrong, the car went about the same 60 ft spinning a little. 1.40 60 ft, 9.07@152 MPH. Damn, another 9.0! But still fun. I lowered the tire pressure back to 17, loosed the front rebound 4 clicks on the shocks, warmed the bottle back up, and went back up there. This time someone oiled down the track, so I had to wait a while. By the time I got up there the bottle had cooled down, was only 830 psi. I tried it anyway, this time it hooked, but only ran 9.11@151 with a 1.38 60 ft. Low bottle pressure is disappointing.
I started thinking, why is it that my 60 ft is barely better than my motor pass when I had the bottle on? Also, right before my pass it was idling at 1800, but my crankcase vacuum was normal, so I sent it. But the idle was fluctuating a lot then, would barely run 1 second at 600 RPM and then 1500 the next. I took the air cleaner off to find out the IAC valve literally fell out and sprung apart! The screws had vibrated loose over the last 4 years of driving and racing I guess. So completely removed it and taped the hole shut, then went to check the plugs only to realize I forgot my tools in the ski boat, doh!
So I borrowed a ratchet from a fellow racer, all plugs looked good. Then I started pouring through the last data log trying to find out why the 60 ft wasn't what I expected, previous best before was 1.303. After looking at everything through the whole run, crankcase vacuum, oil pressure, trans pressure, converter slip, any clutch slip, timing, transbrake off time, nitrous pressure, A/F ratios, fuel flow, air temps, speed, converter lockup, etc. There is so much data with the Holley I have to separate it out to make sense of it. When looking closely at the launch for some reason the nitrous wasn't activating immediately on launch. Then I found a delay I had put in there of .15 seconds one time trying to hook on a cold day at a different track. I thought hmmm, I wouldn't think .15 seconds of juice would make much of a difference in ET, the engine was still running great, and I actually remember running a 9.02 with that delay, which was the best that day, but I zero'd it back out to turn on immediately.
Went back up there expecting about the same result at this point since it was very windy and the track was getting dust over the prep. And I let go of the button and hoooolllleeee crap! It took off it's hardest yet, slowly picked the wheels about 6" and held it there for what seemed like a while but it wasn't. While the front was up I was slammed back in the seat hard enough I had to focus on reaching the shifter to bump second before it hit the rev limiter. About the time I did it gently set back down around 40 foot so smooth I was proud of the chassis work I had done, and I looked up and saw my 1.28 sixty foot on the board and I started yelling! Hell yeah this tank is moving! At this point I am thinking, I needed a 1.29 and I got a 1.28, it might be the one, just keep on pulling! I felt the converter lockup around 135 where I set it in the Holley(feels like a 4th gear at WOT but it’s just the converter). Then you have to get on the brakes pretty hard and fast at 151 MPH, I don't pull the chute at that, I figure my cousins don't pull it at 180 I'm not repacking it for 150.
I pull up to the timing booth and get my timeslip, 8.97@151, finally! All the hard work paid off! I finally met my goal of going 8s on pure pump gas. No race only car, 100% street legal, full interior, heavy overdrive trans, 3.60 gear, 275 radial DOT tire, 3700 lbs with me in it. And its now an official 8 second ride. I keep reliving the feel of that launch and seeing the 1.28 in my head. Its only about .03 faster than my previous best, but it felt like so much more! I know it's not that fast for a race car, but its not a race car. No boost, no race gas, huge radiator, 4 mufflers, full trunk, full interior with back seat, power windows, 4 channel stereo, remote door locks, etc...my first car has become a ride I am proud to say I built. And it has become the best test bed for the Volcano Dry Nitrous system. Spraying that on pure pump gas is pushing it, so the cylinder distribution has to be spot on, and the plugs show it is.
Thanks guys, yeah, the kids love riding in it now. Before the harnesses I could only put Bruce in with the carseat that had its own 4 point harness. But now they can all fit in it. I also feel fine with it because it's quieter now. Before when I revved it up it literally hurt my ears if I was outside the car. The other mufflers were pretty useless.
And the wheelie touched down so soft and smooth it was just like it's supposed to be, up slow and down slow, without bouncing or bottoming. And no "pop and drop" like the old small block with the cheap 90/10 shocks.
I spent a lot of time bracing the chassis and control arm mount with chrome-moly tubing I TIG welded. I had cracked the frame before with the small block, I wanted to make sure it didn't happen again. Plus I mounted true coil overs in all 4 corners. I used Afco shocks from Mencser Motorsports. The coilovers and rear antiroll bar both integrate into the tubular crossmember I added after cutting out the factory coil spring buckets.
I also made a tubular double hump crossmember for the transmission with room for the exhaust that bolts to the chassis bracing. These pictures are from ~4 years ago while I got the car back together.
Thanks, without the chassis bracing I'm sure the frame would be cracked, broken, or bent. I cracked the frame when I was in the mid 10s only about 15 years ago.
Just a 150 shot, a single 68 jet, about 570 lb/hr of nitrous. I was getting almost 200 HP out of it though with my tune. I tried a 71 yet instead of a 68 and started to get the beginning signs of pinging on the plugs with the pump gas previously, so I backed it off to a 68 jet and held it there with no signs of detonation on the plugs. I've made quite a lot of passes on that jet with pump gas from the Mobil station down from the track.
I control the fuel and nitrous with the EFI and injectors. The ECU turns on the solenoid once all parameters are met. Including arming of the system, fuel pressure, oil pressure, RPM, throttle minimum, A/F ratio window, etc. It also adds the amount of fuel I specify on the hit, and can closed loop correct to the target A/F ratio while on the giggle juice. The technology is pretty good these days and you get way better fuel control with 8 injectors vs another solenoid and another jet or 8. And you can tell teh computer if anything drops out of the window you specify during the run, shut it off immediately.
My cylinder distribution is direct into each cylinder with my volcano insert, installs in the same interface as my air velocity inserts.
I’d still like to meet you and see your “toys”. We don’t live that far away from each other.
Yes I remember we are pretty close, been here over 8 years now, its a shame we haven't met, we have to change that.
Another thing I haven't mentioned is the chute mount. Street cars don't want parachutes, but to be NHRA legal over 150 MPH you need one. I've been as high as 153 with it. So my solution 4 years ago was to flip the license plate down I fill the fuel tank with, and have a slip fit pin in parachute. It attaches to a cage bar I bent to follow the trunk lines to maximize trunk space, I've had a huge cooler and lawn chairs in there. It also chrome moly tubing, very light. Once the race is over you just yank two pins, pull it out and clip the cable inside the trunk and flip the plate back up. I left room for a spring launcher just in case...
I was wondering about the 150+ mph and a chute.
Detachable is nice, due to being a street car.
Thanks guys, I've had that car since I was 15 and my father bought it for $300 with a blown up 3.8 V6 and gave it to me for my 16th birthday. Ever since then I just keep making it better and better. But I'm running out of things I want to do to it. It might actually be done? How is that possible....
Perhaps I need to get back on the truck. I can't fit the whole family in it like I can with the Regal, I need to fix that. I have been enjoying the truck the way it is for over 10 years now since I finished the suspension the way it currently sits. Beat the snot out of at the sand dunes and dirt drags, and run errands in it basically.
My ultimate dream machine on the truck at this point would be a fiberglass (or carbon fiber would be even better) 73 blazer tub, a 81-87 nose, full chromemoly hand made chassis I build from scratch, long travel IFS, maybe IRS or long travel solid rear. And a twin turbo 572 all aluminum pump gas big block I would build too. Still 4WD. Basically a giant twin turbo V8 4WD buggy that looks like a K5 blazer and has seating for 5 and a full cage, and is lightweight, awesome suspension, and very powerful. But I am dreaming, I don't have any of that or the money for it. I got the know how, but not the funds, just like a lot of us.
Perhaps I will begin by trying to put a full vert blazer tub on my current frame and drivetrain, and sell my rust free box and cab. But I don't even have that yet.
Here are some videos from the dirt drags a couple months ago. I got two vids from my brother in the stands and a launch vid from my cousin and some friends who hadn't seen the truck launch on dirt before...
The first vid is the finals. My Dad in the Trailblazer SS I call Super Safari. He gutted the thing trying to lose weight, its a stock engine SS with a converter upgrade, I think factory was just over 400 HP. He has me by over 1000 lbs of weight, but I have him by over 100 HP. He couldn't real me back in with that instead of the Willys unfortunately for him.
Then I raced likely the fastest SxS there. Was a Polaris RZR XP Pro cranked up to over 28 lbs of boost. It was close, but I beat him, twice in a row, he's a friend of ours. Its a real nice fast ride, I drove it after and it scoots! I think he has a major traction issue to be honest, its spinning the tires a lot.
The last vid is low quality because it was a vertical vid I cropped. But its a launch closeup, my spring wrap is pretty bad..
That's how the side by sides keep from destroying cv shafts and drive train. Lack of traction. A guy I knew had a regular rzr all stock but lifted with 32" truck tires. They were using it in some pretty sticky clay mud out in the desert patrolling power lines and it started having issues moving and had twisted off both left side cv shafts. Looked like they had been cut in a band saw.
You could always add a family style cage and a securely mounted truck bench seat to the bed of your truck so the kiddos can all fit at least when the weather is nice and do like a bikini top for shade. I ran into similar issues with 4 kids. I always gotta have a 6 seater to fit everyone.
That's an option, but it doesn't solve the weight issue, it would just add weight, ha ha! The thing weighs about 5200 empty right now. I think for safety sake, I need a lightweight blazer cab with a full cage, yeah, that's it, purely for safety.
Great story about having the Regal since such a young age. I've still got my first car I got at the same age. Hopefully soon I can start getting back to it to have fun with it again. Plus I'm a g-body nerd too. We have a factory 4-speed '78 Malibu Classic coupe Dad bought when I was 12 or 13. I tore up the clutch good in high school. Put a McLeod in it after that and it's been driven twice. Sitting in the back shop waiting for me to bring it to life again.
I dig the plans for a crazy Blazer. Keep it up with the biz and bet you have some funds coming in sooner than later! Killing it dude!
