MikeWho
Registered Member
When you turn the flashers on everything works the only problem is with the back lights won't work for the left signal and they both flash for the right signal. The right signal on the dash stays on when the lights are turned on. The light under the headlight on the passenger side doesn't work but it has power. Must be a ground issue. The light inside the grill on the passenger side is really dim when the lights are on but the blinkers and flashers light up normally. Any input would be appreciated this is the last thing to tackle until I can take it on its maiden voyage on the streets. Thanks
