Yea I shoulda have thought twice before using goo gone as I have tons of other stuff in my service truck, but oh well white it is!
There is not a lot of components in there, but there are a few. Its too much trouble for that amount to do a heat calculation. After you get the system up and running, check the inside of the box for temp. If its running warm, you will have to come up with a way to dissipate heat.
I designed and built some units for a guy a few years ago. Used about the same box, except it locked with screws instead of latches. I knew the environment they would have to work in, so I made sure everything that pierced the box was NEMA4.
After the first couple, he asked if I could not make them smaller. Said that there seemed to be a large amount of room, so a smaller box should do just as good.
I told him no.
After about 8 boxes, the job ran out. That was actually 2 more than I expected. Of course, I sent a BOM along with schematics and a single page op manual with each one.
About 6 months later, one of the guys who worked with him mentioned that those new boxes I built were not working worth a darn.
I was a little curious, since I had not built him any new boxes. Turns out that he found out he needed two more, and got a local guy to build them for him.
To save money and space, he used much smaller boxes. After about a couple of months, they failed. He fixed them, the new ones failed.
As a result, the guy lost those two accounts. He never called, or asked, so I did not volunteer any information.
The reason I used those large boxes was not room inside, but surface area. I wanted the boxes sealed due to the area they were going to be used in.
That fiberglass box material does not transmit heat all that well, but if its big enough it will not get too hot inside. The smaller boxes did not have enough surface area to radiate off enough heat and so the components overheated and failed.
They make shielded vents that mount on top of those, and combined with a couple of holes in the bottom covered with really fine screen wire should be enough for your system if needed.
In my case, there would be lots and lots of super-fine dust floating around along with occasional water sprays. I did not want to take the chance.
If I had needed more cooling, a couple of large heat sinks mounted back to back one inside, one outside sealed to the case with some kind of heat pipe or transfer medium between them and an inside fan would have been my next choice.
J.
