gotblazers
I picked it up a few days ago and i gave it 20/40 gallons to give it a full tank and some enzyme additive supposed to clean out the fuel system. Then i drove it home. It needed a jump to start. It had no problem holding 55-60 mph the whole way home.
1.It stalled out on the freeway offramp. Couldnt start it again and it was saying ''water in fuel'' when i tried to start it.
2.we towed it over to a nearby parking lot with the follow vehicle and jumped it for 20 minutes and drove it home another 15 miles and it seemed to have an issue holding idle.
3.I tried to start it the next day and it still said water in fuel so i changed the fuel filter
4. I tried to bleed it but i couldnt find any way to get a hose fitting inside of the air bleed valve to get the diesel coming out nor could i find the return line to the injection pump to hook my compressor to and i would have no way to tell how much psi i was actually putting in anyways with my compressors ****ty old regulator.
5. My dad decided it was a good idea to put fuel down the air bleed screw hole so we put 3 rustoleum paint caps full with a custom made foil funnel of diesel down the hole but theres still no start and its still saying ''water in fuel''.
Ideas,suggestions? Im pretty lost here.
, Damn diesels
