84 blazer 90% done or for parts
73redblaze
Aptos ca
this is an 84 chevy blazer rock crawler that is registered as a green sticker vehicle. offroad use only. This truck is built with the top of the line. strongest products. Only WFO concepts, Ruffstuff specilties, Ballistic fab, DIY4X and OffRoadDesign were used in this build.
84 chevy blazer
Edelbroc 350 crate motorless than 50k on motor
700r4 trans
np208 t-case
Suspension:
64" springs in the rear with DIY4X shackle flip and swithch with 6" DIY4X shackles
56" springs in front with DIY4X spring hangers front and rear, 7.25" DIY4X shackles
ORD U-bolt plates and u-bolts front and rear
BRAND NEW still in box (4) procomp es9000 shocks 15" travel
Axles:
Dana 60 front axle, 4.10 gears, with brand new rotors, wheel bearings, and brake pads
14 bolt FF rear axle with 4.10s, clocked up to match t-case
home made torsion bar using diy4x mounts and hangers
Crossover steering:
Ballistic fab crossover .250 wall dom draglink and tierod
6"drop pitman arm
ORD steering arm
Tires:
Kore beadlocks with 0 miles on them pro mounted
37" Bogger super swampers
I have seats for the truck that still need to be installed. The truck is not 100 % finished, all that still needs to be done to have it ready to wheel is hook up the brakes and install the seats. Truck runs great. I have over 8k in and i want to try and get $4000. my 16x8 tandem trailer can go with it for a total of $5500. Any questions just e-mail me. Thanks
If you do decide to part it out i'll take the 2wd steering box w/pitman arm and shocks. let me know.
I already have a ballistic fab kit, I just need the box and Pitman arm. The nearest pick & pull is over an hour away. I figure paying shipping is a lot cheaper then paying for gas.
