I bought this truck on an impulse. It was an un-finished project started by the P.O., It still needs some work. I have lost interest & just ready to see it go away.
The details:
Unknown displacement center bolt valve cover, passenger side dip stick SBC. It has a 4 barrel carb on it. T-350 transmission. D70 HD rear with unknown gear ratio. Truck started life as a single wheel. The P.O. put the Dana 70, rear sway, & bed on the truck. When I acquired it, it still had SRW front. I swapped the spindles out to DRW. The cab is in good shape. Passenger front door is dented. The bed is dented in front of the passenger side rear dual. P.O. started a '89-91 grill swap & I finished that also. Paint is pealing, but the daully rear fenders are in very good shape. Interior needs some love. The door panels are mix matched, & the front seat is a pair of buckets from a newer model truck. It also has a Fabtech front leveling kit on it. I found a set of P30 motorhome 19.5's with new 8r19.5 tires. I put them on it.
Price for truck without 19.5's on 16" rims & bad tires - $2500
Truck with 19.5's - $4000.00
The details:
