My truck had an electric fuel pump mounted on the crossmember behind the cab when I got it,but it was not connected or hooked up!..looked brand new too..
Someone had butchered the dual tank setup on it--they removed the switch on the dash,and the valve under the truck was also gone,and someone had mickey moused the plumbing to the two tanks with lots of rubber hose and a manual three way valve..one fuel tank leaked,so I decided to chop out all that jerry rigged crap and run the truck on just one tank--and I found that electric pump worked fine,so I decided to wire it up and use it as a booster to feed the stock mechanical lift pump..(which looked new BTW)...
After I got everything installed and bled,I noticed the truck ran smoother and seemed to have a bit more power with the electric pump switched on--I can shut it off and the truck will stay running ,so I guess the lift pump can pull fuel thru the electric pump when it is off--I leave it on all the time though,its wired to the ignition so it works only with the key "on"...
I do have to keep an eye on my oil ,because if the lift pump did decide to lose the diaphram,the electric pump could well fill the crankcase with diesel fuel...so far so good ,its been 10 years so far and no issues..I like having the electric pump because in the event you ever ran out of fuel or had to open up the fuel system and let air in it,it self bleeds after you open the bleeder on the fuel filter and turn the key on--once fuel comes out there,it'll start up quickly after closing the bleeder..
