84 mechanical clutch linkage
fallguy
montgomery tx
i am in the process of putting my truck back together. its a 84 w/ sm465 tranny. it currently has the ord 1" body lift kit. for some reason the rod that goes from the bellcrank is pushing the clutch fork down causing it to rub on the bellhousing. i already have the longer speed direct clutch rod w/ heim joints but it is not helping. i think i'm missing a spring or two that connects to the clutch fork. does anybody have any pics of the setup or maybe ran into the same problem?
