85-87 Neutral Safety Switch Pigtail?
Bowtiek10
Colorado
I'm trying to find a part number or be pointed in the right direction to find a pigtail for the neutral safety switch on the hydraulic pedal assemblies out of 85-87 trucks. I've been searching it quite a bit, but I haven't come up with anything yet. Here's a pic to be extra specific. Thanks in advance
70's style gm truck wipe motor use the same style plug .
I had one once and I found it fit good .
I'll give this a try. Thank you! You seem to be very informative on this forum and that goes a long way for new guys like me
shhhh :ignore: don't tell anyone
the wiper motor plug I told you is were I got mine for one I never installed before going auto . but they did fit in the switch . might have had to trim a alignment tab down I forget .
You wouldn't also happen to know how the switch is wired would you?
If I'm not mistaken those are the "neutral start" wires, and the other terminals would be for the cruise cutoff.
