Had my windows working although needed to replace the switches and connector where the switch plugs into. Connector wires had broken off. After soldering in new connector and installing new switches, got zero power to the windows.
1) checked fuse PWR WDO which looks good.
2) read something about the 30a 12v fuses. Swapped those to see if one was good.
3) both doors and motors are connected with wiring and switches
4) read another post about ah orange wire in steering column... no idea on that
5) while waiting for new connectors, I ran some speaker wires and was near fuse box.. not sure if something got pulled off. As I look now, seems to be a orange loose wire.. no idea where it belongs in fuse box if at all.
**update: checked pink wire and I am getting power up to the connector. Tried new and old switches, neither works**
Any thoughts?
Any thoughts?
