Before I pulled the engine out I labeled all the wires however that was almost a year ago and now that I'm finally able to work on it some of the labels have worn off.
These ones come out of the firewall about a 8 inches towards the drivers side of the ac/heat stuff. Some of them go through the fire wall and the other's go some where in the engine bay but I don't know where. One is a four pin plug and the other is a two pin both plugs are male.
These ones go to the heat/ac stuff on the firewall. (There is a big mess of tape and wires and these may go into the firewall right beside the heat box not to the box) Two light green connected to one spade (seems to be the inerds of a male plug)
The other is dark green and has a single pin male plug with a female port of to the side. Kinda makes me think the light green ones plugged into the back of the dark green and then they plugged into something.
Also what is this vacuum line for? One very small line goes through the firewall then to a T from the T one bigger line goes across the firewall to a ball on the drivers side bottom corner of the firewall (what's this ball for?) The other is cut.
The ac currently doesn't work but I do plan to fix it some day. And all the emissions stuff isn't important it's primarily off road and Kansas has no emissions checks.
EDIT -Sorry it's kinda hard to see which wires I'm talking about. When i get to a computer i can edit the pictures to highlight the right wires.
