Got an 85 Jimmy 4x4. Carbureted that I'm having trouble with.
1) Fires up fast and easy cold. But struggles to fire after its hot. It goes eventually but man. Takes a few minutes.
2) Runs and drives fantastic. I drive it to work sometimes. Runs and idles well. Purrs like a kitten. But the 2x I've taken it off road, it starts to idle rough and what seems like a misfire. Sometimes when giving it a little gas across the parking lot it kinda revs up and down. But then I drove it 2hrs home and it was totally fine. Could this be a dirty carb issue? I do know there is currently no fuel filter. I've only had it a few months. Still shaking it down.
3) What is the best off road carb? I know fuel injected is best. But I don't have the money or time for that yet. I have a 350. Do I need to worry about CFM?
4) Lastly I am hearing a grinding sound when trying to engage 4x4. Like its engaged but slipping? Sounds like the diff or the manual hubs. not the t case. Do those locking hubs go bad? They are WARN. I did install now motor mounts and such. And the shifter and indicator aren't staying at the 2H spot. Could it be I just need to adjust the shifter linkage?
Any and all help on these would be so great. Thanks!
