'85 K20, ex-K30 *Sold* thanks
Goose
South Central Kansas
1985 Chevrolet K30 that now has D44HD front axle, 350sbc, TH350(mild shift kit), NP203, 14bff. 4.10 gears, front axle has drive flanges.
Rear axle has new brake shoes, cylinders, wheel seals, turned drums.
Front axle has new brake hoses, all new seals except inner axle seal(next to diff) plus new pinion bearings (at hubs). Bearings repacked with Lucas gear lube.
Within last two years, new master cylinder, alternator, front and rear main seals, valve cover and timing cover gaskets, all fluids in both axles, x-fer case, tranny, and radiator.
Spare tire has matching wheel, but different tire tread.
Rino lined bed, draw bar.
Has some rust started on lower door corners and some small dents/dings.
T-case chain has play, if used for daily driver would want to replace it.
Asking $2000 OBO, delivery MAY be possible.
Located in Wichita, KS.
I can get other pics if requested.
Forgot...dual tanks, both 20gal, switch works, both fully functional.
Also new, driveshafts and u-joints in both ends of both.
Bruce--can you post some interior pics? Are you wanting cash only, or are you looking for trades? Where in Wichita are you located?
Jeff
Sorry, need to sell, not trade. I have three trucks now.
I could only find two interior pics.
The rust on the floor is not as bad as it looks, I was cleaning and some of the floor is still wet.
I pulled the old factory stuff out and just have a rubber cover now so any water will evaporate.
It has sun visors now also, along with ashtray, and the trim piece under the steering wheel.
The brake controller still works, and well too.
Dog NOT included.
Missed one question...
Actually in Maize, just on the NW side of Wichita.
Also, the seat may look rough, but the springs underneath are still fine.
No saggy butt.
Will send a PM. I know someone who may be interested in this truck. We saw it sitting at your folks place by the tracks.
Xtremjeepn said:
The c30s never had a D60 front either:wink1:
I realize the C30 were 2wd, but this truck definately had a D60 up front. I know as I swapped them around. This truck came factory with 4.56's. Since I wanted them for my 90 K5, I swapped out my other D60 that had 4.10s in it. Now, apparently Goose has since removed that axle.
For additional info, that truck was a very good truck for me when I had it. I really wish I had never sold it to Goose.
