For sale!
No emissions in all 50 states
No DEF
No EGR
Clean title
20+mpg
Camper Special
One of a kind
1985 Chevy Silverado K30 4x4 1 ton utility truck. 6.2 L Diesel with a FULL Banks Sidewinder Turbo Kit. NP205 Transfercase, SM465 Manual Transmission, Dana 70 Dually Rear axle, Dana 60 Front axle, 4.56 gears. Starts up every time! Runs and drives great! Comes with crane jack, vice, spare tire and rim, has Oem Jack, utility lights, extra used turbo, extra new turbo, extra new Banks air filter, extra glow plugs, and extra gaskets. Has good tires, great heater, A/C parts if you want it, extra belts, behind seat storage pocket caddy. Pyro, tach and boost gauge. New matching convex mirrors, new power steering pump, new rear view mirror, fresh tune on ip, CB antenna. Block heater. New horn button. New Coolant reserve tank. Newer Interstate battery.
It has a lot of power.
Could use a new ignition switch, tilt column is kinda loose, tach and pyrometer gauge flicker off and on, guessing bad grounds. Driver utility box rear door bent. Can be bent back with a rubber mallet. Light cancer in cab corners. OEM stereo no worky. AC bezel vent fins broken but have a replacement.
The more work I do to it while waiting to sell, the higher the price goes.
$8,500 OBO
Located in Belgrade, Montana.
Send me a pm if serious! Video of it running great if requested.
No DEF
No EGR
Clean title
20+mpg
Camper Special
One of a kind
$8,500 OBO
