Goose
Starting family, gotta cut back on some toys....
1983 K30 dually, 6.2NA, SM465(hydro), D70HD, D60, 4.11s
Exhaust is a little rusty, but still working, not loud.
Tires are about done.
I spent about $2400 this last year on brakes and suspension:
New master cylinder and hydro boost unit, new extended brake lines front and rear. New rear hard line from under cab to wheel cylinders.
New rear drums, shoes, hardware, wheel cylinders. New D70 u-bolt style yoke. New springs front/rear. New ORD front upper spring hangers. Greasable bushings. Rebuild kingpin, seals, repacked front bearings. HD tube bumber with Warn 8k winch. PTO off of transfercase with shaft to hydraulic pump, plumbed to rear with quick disconnects. It also has line lock to front brakes and e-brake works, so you can set all four tires if you really don't want to move. (nice if winching something big)
Truck is really set up to do some work. Would be ideal for tree cutting/hauling, esp with a hydraulic splitter.
Issues include having death wobble. Getting alignment on 07/24 to see what that does, about everything else is new or solid. Water pump drips every couple weeks and used a little coolant on long trip. (3 hrs) Short trips (1.5hrs) at 55-60 uses no coolant. Gets about 15mpg at 55-60, 12mpg at 70-75.
Asking $4500.
I can take pic of whatever you want and post it.
Hear are a few to start with.
Asking $4500.
