If with the inner spacer I'll push the outer tire out past the hub centric, then even with the tapered ring that tire will not be centered correct? I'm definitely not against installing longer studs, but with the inner spacer wouldn't I need to taper the outer rim to keep it centered? Or use an inner spacer that had some centering ring on the ID, if there is even enough room for such?
