I have a question on my harmonic balancer. I have the 3 groove rubber dampened pulley balancer that has a 4 bolt pattern. I understand it was put on the 86' and up engines to help prevent belt oscillation. My problem is when installing the torque converter bolts my brother went to turn the motor by the pulley with his hands. The pulley will turn, with a lot of effort on the rubber without turning the crank. The rubber all looks in good condition and doesn't appear to be deteriorated in anyway. I'm curious if this is how it dampens the oscillation or if it is bad. I will be running AC and need the 3 groove pulley but understand I could just run a hard mounted 3 groove pulley. Will it slip trying to turn all the belts? Not sure if the motor will have more noise under the hood going with the non-dampended pulley. This will be a everyday driver that the wife will drive and it needs to be as quiet as a 6.2 can be. I know, that's kind of an oxymoron. What 6.2 is quiet?
