86 burb wiggley
tumbleweed1002
copperas cove ,TEXAS
:burb: my question is I have an 86 burb with 8" lift and 37"boggers I noticed the other day while my son was running through heavy mud that under hard throttel the front tires seem to wiggle,I have checked the wheel bearings,ball joints and tie rod ends and all seems ok, when jacked up the front end appears tight so is this normal? also on the road it dose not pull or shake (some vibration from the boggers) but otherwise normal.
do you have any pics of the truck? just curious!!!
