MichiganderK5
Registered Member
been lurking on here and finally thought i should share my build
i found this 86 gmc jimmy on craigslist, was originally a 6.2/700r4 truck. then had a big block in it, it had a warn winch bumper and a warn 8274 winch, when i bought it it had a bone stock 350 4bbl and th400 out of a k20 in it, had mismatched 10 bolts in it and lift blocks on the front
Body looked solid with some rust in rockers, but rear floors and tailgate area was rock solid, supposedly it had been parked for 10 years or so, looks to have had been original grey with blue down middle of truck.
ended up loading it on trailer for $1500
i picked up:
D60 drw and 14BFF for $600
AC Delco SRW hub assemblies for $400 pair
4 inch front springs for $75
flowtech headers
GLO disc brake brackets
Mile Marker SS hubs $50 from pawn shop
Diy4x shackle flip and switch with cross-tied shackles
zero rates
UD spring plates
Edelbrock preformer EPS
Edeljunk 600 carb
and proceeded to install....
i picked up:
flowtech headers
zero rates
UD spring plates
Edeljunk 600 carb
. What's your overall plan for it? Or is it pretty much there?
