86_M1009
1986 USMC M1009 CUCV K5 blazer
View attachment 190441 I come in search of help.
I have an 86 k5 blazer rescently bought in excelnt runing condition and with only minor issues.
One of these isues is the tailgate window ferame being cracked at both ends. This is a manual tailgate and the cracks were discobered while rebuilding the inside due to tje rollers wearing out and the felt and seals being 30 years old. The cracke radiate from bothe ends of the window opening. I want to stop drill and weld the cracks but it seems like this might be a waste of time and it will just keep happening due to a flawed design. I do know that this tailgate was a junk yard replacement for the original but I do not know if it was damaged or not before the transplant. It does loom like some pulling has been done on the rear lip of the opening becaause both ends are slightly higher than the center qs if they had been beat down by someone loadi g crap into the back and someone else tried to pull it back up to the original lines but went a little to far, resulting in lifti g of the metalat the ends wher the rear lip is welded to the sides. This is where the cracks are, the pint where the sheetmetal that is rolled over at the top of the gate and welded to the side frames just above the latches.
I see my options as:
1. Sand, hammer, welp, prime and paint.
2. All of 1 but cuting the tailgate open to add bracing strips to strengthen the ends where the cracking is happening.
3. Buy an electric gate and salvage a factory set of window controlls from the junk yard?
4. Find out if there is a custom flip up rear window and instal a c/k gate.
5. Any and all advice and outside the box solutions will be entertained. Especially if you have delt with rhis issue.View attachment 190440 View attachment 190440
