loafer
1986 K5 Blazer - $3,900
General:
- soft top ($600 new in 2006) and hardtop included
- Heavy duty winch bumper (winch not included)
- New inspection sticker
- Truck is originally from Georgia, then moved to Texas before coming to Maine.
- New radiator & radiator hoses
- New inner fenders
- New battery cables
- Sony CD receiver
Tires :
33 x 10.5 BFG Mud Terrains, approx. 75 - 80% tread and full size spare
Rear Axle:
- 3/4 ton 9.5in 14 bolt converted to 6-lug (8-lug axle shafts and drums are included)
- 4.10 gears
- Powertrax locking differential ($600 new)
Front Axle:
- stock 1/2 ton from an 88 K5 completely rebuilt in 2006
- 4.10 gears
Engine:
- Crate 350 with approx. 70K miles
- Edelbrock intake
- Holley Commander 950 programmable EFI ($1300 new)
- All new dual exhaust in 2009
Transmission:
- Auto w/ OD (700R4)
- B&M extra capacity pan
- B&M heavy duty auxiliary cooler
- Bowtie Overdrives adjustable TV mounting system
Transfer Case:
- NP208 with slip yoke eliminator (Drilled and tapped the output shaft)
- Custom CV rear driveshaft ($450 new)
Suspension:
- 3in lift, all springs
- Off Road Design steering box brace kit
- Off Road Design sway bar bushings & disconnect/correction kit
- Ranch RS5000 Shocks (new July 2010)
- Heavy duty front tie rod and tie rod ends
Included spare parts:
- Edelbrock carb (needs a float bowel gasket and an accelerator pump)
- AC compressor and condenser
- hub caps & beauty rings
- extra set of stock wheels
- spare 4WD hub parts
- brake master cylinder (new)
- factory rear drive shaft
- Lots of other little stuff
