Blue87K5
Registered Member
I just completed a full wiring harness replacement. Before the swap the truck would fire up like a champ cold or hot. Now after wiring harness replacement I need to crank the truck 10+ times to get it to fire up (cold or hot). My specs are:
Edelbrock 1406 electric choke, ZZ4 350, Edelbrock manual fuel pump, HEI distributer, Keepitclean 85 K5 wiring harness
The only thing I did different is I disconnected the oil pressure switch. I connected the Oil pressure gauge to the oil pressure sender. I connected the electric choke wire directly to the choke. The stock harness had the choke wire going to the oil pressure switch and then to the choke (I think that's how it went). Would disconnecting the oil pressure switch on a Carb'd 86 K5 cause hard starting issues. I know on 87+ K5s the switch acts as a backup fuel pump relay. My other idea is to remove the manual fuel pump & add an electric 5-6psi pump. This problem is really starting to piss me off. Any help you folks can provide would be great!! Thanks
Donnie
Donnie
