I here you. It all adds up,and snow balls out of control. That's why a lot of people just make there own parts,Igeuss.Best to amass parts slowly over time,that's what Idid.I figured it would be best to do a lot of research and do it right the first time, rather than having redo everything and add cost/frustration. If I were you the first thing Iwould do is get rid of the half ton rear. Do the junk yard crawl for a full float 14 bolt. You want the one from a suburban.They have the spring perches in the right place, but a 1 or 3/4 ton truck you would have to cut off the spring perches and reweld in the right locations, then regear the front 10 bolt to match the back/ find the parts to make 8 lug. of course it would be better to find a matching pair of axles from the get go lol.You might find someone on here that has done the 52 swap and wants to sell their old lift kit. A buddy of mine has a k10 and didn't want to spend a lot to lift it , he decided to get a 1 inch body lift and 1 inch zero rate add a leafs from offroad design.Clearenced the front fenders slightly for 34 inch super swamper ltb tires , looks pretty good. although the truck has no balls at all with the stock gearing in the axles , unless he puts the t- case in low and the trans in L1. LOL
