86 K5 with a 6.0L LS - tell me what you see
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
Well, the 88 my neighbor has may be too much of a survivor for myself and my budget. He knows it’s a gem and it’s going to be priced as such.
Soooo…found this
If you don’t have the Book of Faces:
IMG_9914.jpegIMG_9915.jpegIMG_9916.jpegIMG_9918.jpegIMG_9917.jpegIMG_9919.jpegIMG_9920.jpeg
Asked the guy about it. Sounds good so far.
“drive it any where has 456 gears factory ac works good blazer no rust”
Looks like 4” and 33’s or 35’s. What do I need to be asking?
Great power train combo, had the 4l65 ever been touched or rebuilt? so many questions about the swap, how's the fuel system is the gas tank baffled? who made the harness, is it factory ls pcm or a after market like a Holley set up, in tank or frame rail fuel pump? The 4.56 gears will be happy with 35's and the OD on the transmission.
It looks like a really nice truck and a great driver as is.
I’m betting that’s 2” lift w/ 32’s or 33’s. (you can measure the front to verify)
“No rust” but I see orange above the windshield and possibly in the door jamb at the top / front corner. It may not have rust holes but it’ll need to be addressed to prevent through rust and paint jobs have skyrocketed like everything else.
Talked to the guy. Older gentleman, like 70’s. Says it’s too big for him to climb in and out of now. Runs a classic car/parts business.
Said he bought it 10 years ago with a knocking engine. His son put a 350 in and that started having issues about 2-3 years ago so they went to pull another engine which ended up having issues. At that point he sourced this 6.0L out of an Escalade. Said the trans came from the same vehicle and it’s all set up stock using the factory computers.
Says the roof rust is just surface. Again, said he’s too old now to get on a ladder and scuff and paint it. Solid body otherwise. New carpet.
I didn’t ask about the rear bumper but he did say it’s got a 12 bolt rear so I wonder if it’s cobbled together from multiple ages of Blazers?
Question for you guys - it has a rebuilt title. He got it from CoPart after someone blew the original engine and apparently scrapped it due to this. How good / bad is that?
A salvage title can make registering and (mostly) getting insurance difficult.
I'm always skeptical of those. I'd be checking all the body stuff to make sure it wasn't crashed bad.
Do they really change the title because someone rebuilt the engine? I've been given that line before too and I am not sure I believe it.
I asked for the VIN. He says PO had scrapped it due to the engine dying. People do dumb things like that.
If I remember correctly, it means the vehicle was in some way put in salvage status (voluntarily turned signed over to a junk yard, totaled by insurance, etc.) then at some point someone repaired it and submitted it for inspection to have the title revised as “rebuilt”.
If it went through a dismantling yard, it would have a rebuilt title. Someone there was smart enough to save it.
Check with your insurance. Knock about $3k off of the price because of that.
Yeah I'm not saying its a showstopper I'm just saying check it over thoroughly and the price should reflect that.
