87 14bff hub nut question
surpip
1 ton status
sacramento ca
/forums/images/graemlins/1zhelp.gifhow do you set this up? is it like the front tighten than back 1/4 turn its the single nut setup with the 1/4 key stock to lock it with the c-clip that goes arount the axel threads, thanks alot,
dale
Yep you set it up just like any other adjusting nut.
Crank it down, back it off, torque it and back it off.
Install lock and clip.
like setting wheel bearings, torque/preload then back off til zero lash basically
good luck
