scotsdale83
I am having some problems starting my truck. Its an 87 350 tbi. The truck will crank over like theres no tommorow. When you turn the key on you can hear the fuel pump run. It will start then die. Repeat this several times for like 20 minutes and it will finally start and run. It seems to run fine once it starts running. Any suggestions? The time the fuel pump runs when you turn the key on gets longer as you keep cycling the key. I tried the relay on the firewall with no luck. The pump was replaced a couple years ago.
Thanks for you help guys
