idislikeunc
Registered Member
Flexed out the blazer today to test shock length and check for tire rub. 4" tuff country front with ord disconnect, front 33's rub on the firewall side of the fenders, time to cut the corners!
Rear shackle flip in the back worked great, no rub and I think I got the shock lengths right on the first guess.
Now for the questions.
First, I have some play when I shake the wheels, suspect bearings are bad. Also, hub bodies are loose (not the 6 outer hex bolts but the inner body itself). I'm gonna take apart the front end tomorrow to see if spindle nuts are loose or if some snap rings are missing. Anything else I should look for? How do I know if the bearings are bad?
Second, I picked up a new vibration/grinding noise on the highway today. It only happens between 50-60 mph when I let off the gas. If I slow down or put my foot back on the gas, it goes away. Sounds like it's coming from the transmission or possibly the rear diff, but I don't have a clue where to start.
Thanks for any help, or for just looking at my pictures. They aren't the best shots, but I'm waiting for my buddy to email me the rest.
Paul
Paul
