87 F350 4wd C&C
1-tonmudder
In a junkyard somewhere
87 model F-350 1-ton C&C with walk-in utility bed.Truck has a DW 60 front,Sterling rear,both with 4:10's,NP435 four speed,BW1356 case,carbed 460.Odometer is showing 81K and is suppose to be the correct mileage but I cannot verify that.Needs a little TLC but would be a good work truck or remove the bed and have a cheap tow rig.$3200 located in Greeneville TN 37743.
