'87 grill to a '90 ?
Blazerater
Registered Member
Hughson, CA
Is it much of a pain to be worth it? I would like to but I'm not into the whole re-wiring thing?
Wouldn't be too hard to rewire . You have a ground , and you have a high and low .
I did a single headlight each side to a dual halogen each side on a 93 work truck and just cut the ends off , used a meter to see which wires had power in each position , then just wired the new plugs to those , of course I had to splice two wires off of each sides single gorund wire .
The simple way, get the core support/grill assembly, and the wiring harness with it. Bolt in core support, route harness along fender, plug harness into firewall. Done.
Yes, this is the easiest way.
If you don't get the core support, you have to fab up brackets to hold all of the lights in place. That is harder than the wiring, which is nothing more than putting new connectors on.
