Unless your burning chips? There's nothing to change. The Patches are more an advanced thing. You change what data the chip puts out, in this case it is replacing the Prom ID and O2 Cross Counts for Spark Advance and Base Pulse Width. Both more useful data.
It may run better with the 10k switch on... but don't do it because it will now give false data for whatever problem your looking for. The 1227747 ECM that comes in these trucks does not need 10k switch for data.
Like idle is increased, depending on chip, to 750-1000 RPM... spark advance is also increased with 10k switch on.
The sucking air noise you hear is air going through the IAC valve instead of over the throttle blades. This does not help idle! Since the injectors are on top of throttle blades, the idle quality is much better when all the air possible mixes with the gas. This helps mixture and keeps your wet intake as dry as possible.
Why it changed? I don't know?
What kind if issue are we looking for?
The O2 sensor reading is not much help in data because the ECM causes Cross Counts. So it is constantly, when in Closed Loop going high/low for the Catalytic Converter.
