87 Blue Beast
im finally starting my build after alot of thinking. i got my tires and wheels, and i have the lift kit ordered. heres what i got/ordered so far.. 38.5x15x15 tsl boggers, 10x15 rock crawler wheels, rough country 6" suspension lift kit, 3" per. acc. body lift, and 1" zero rates (total of about 10" of lift.. for now
). after i get this lift and everything done, im doing a 1 ton axle swap, a sm465, backed with a 205 t-case. then when thats all done, im building a sbc 400 (406) to power the beast. as you can see, i have my work cut out for me.
today i mounted the tires on the wheels. im waiting for the lift kit to get here to start on everything. i have a couple q's to start off with. with 10" of lift and the front axle moved 1 or 1.5" forward, will i clear the 38.5s with out cutting the fenders? if anyone is running 10" of lift with 38.5s, can you post a pic for me? ill post pics every time i get parts or install something
. if anyone has any advice along the way, dont hold back because this is my first time doing a lift
). after i get this lift and everything done, im doing a 1 ton axle swap, a sm465, backed with a 205 t-case. then when thats all done, im building a sbc 400 (406) to power the beast. as you can see, i have my work cut out for me.today i mounted the tires on the wheels. im waiting for the lift kit to get here to start on everything. i have a couple q's to start off with. with 10" of lift and the front axle moved 1 or 1.5" forward, will i clear the 38.5s with out cutting the fenders? if anyone is running 10" of lift with 38.5s, can you post a pic for me? ill post pics every time i get parts or install something
are they all like that or do they varry according to size? its not that big of a deal.. its probably actually better for me becasue thats more clearance
This is just my opinion. Good luck with the build, cant wait to see it jacked up
. second problem, the shocks they sent me with the kit are two short. when the truck is just sitting there on level ground, the shocks are completly extended to teh point that they are compressing the rear suspension a tad
the steering arm removel is a pain in the ass, you just have to beat on it with a hammer, and lots of lube, also try a chizel in beetween the washer cones, thats how i got mine out
