87 K5 Horn - Dome Circuit shorting
Dre007
California
So my Blazer’s dome / horn circuit was working just fine. Until I swapped out the dome and under dash courtesy light with LEDs. I was getting ghost lighting on my dome lights so I saw that installing a resistor (idiot move) on the dome lights would stop this. It did. BUT, then after sitting for a couple hours, something burned and shorted. The the 20A fuse blew and the under dash light wouldn’t turn off, with door open or closed. When I open the door the under dash light lights up all the way. When I close the door, it dims slightly. As soon as I replace the fuse, the fuse pops. Pulled the horn relay, and inserted new fuse. It popped. I checked continuity on the dome light by hooking up both leads to the bulb connectors and it’s pulling 1.6 ohms. When I open the passenger door it drops from .6 to .8 ohms. Not sure what I got going on here. I’d appreciate any suggestions.
If you have dim dome lamp, either door switche/s are bad, or you have a weak short to ground. This short may possibly be to another wire, look for a hot melty spot in the loom and investigate
Door switches are good. I replaced both and the problem doesn’t go away. I definitely have a short to ground. I ordered an ETC3000 in hopes of finding that short. I’ve looked all over for it . It’s pretty a fairly simple circuit and wire run. Only thing I can see is the wiring that runs into the roof of the cab. I don’t know if I have to remove the hardtop to look at that wiring. The hardtop dome Light will power for a second before the fuse pops.
That is a weird circuit that can end up with the courtesy and dome light in series when you blow a fuse. I think it could be re-designed to put them strictly in parallel with the lower current draw of LEDs.
What resistor did you put in the circuit? My guess is that you heated a wire and melted the insulation, so that now it touches. One solution is to abandon the melty wire and run a new one, but the trick is to figure out where the issue is. You could try disconnecting the wires from everything you can unplug and see where the short goes away.
Here, I've cut out the circuit. See how there is 1 fuse for the dome and 1 for the courtesy. Which one are you blowing?
I believe the cigar lighter is on this circiut as well
I’ll check that as well. Got the Power Probe ETC3000 that I’ve seen great reviews on. Of course the one I got is defective. Have to wait for the new one. I’m hoping that help with finding the short relatively quickly.
I’ve tried that and it still blows as soon as I connect my battery.
