87 k5
Florida K5
Registered Member
Florida
What is the most inexpensive spring suspension lift that I can put on this blazer. Also what is the advantage in putting a Shackleflip on
I put an all spring 4" spring lift (Tuff Country) on mine for under 1k.
The shackle flip will give you close to 4" in the rear and will set the pinion angle up as well.
