87 No start
panicx
Newbie
I was driving the other day and my truck just died.
I found a blown fuse "ECM" replaced it, Got it in the driveway and it died again.
Same fuse. Replaced it and now I have no start, No check engine light.
I have checked every fuseable link i can find.
No power to ECM , fuse is good.
Any one have a diagram that is better than the Chilton ? Or ideas ?
1987 GMC Jimmy full size, 350, auto, 4x4
I had a similar problem turned out the + battery cable had worn threw and was touching the frame. Check out you battery cables.
Found that the power wire coming from the starter was touching the exhaust manifold.
Got that fixed. Still no check engine light. Could i have fried the comp ?
I see a 4 bbl intake and carb coming..
