Hello
I'm going. It's trying to get my truck started and I'm hoping someone here can help me.
The truck is an 87' GMC V1500, it came with a 305 and a 700R4 from the factory. The 305 had a catostrophic failure and needed to be replaced. It was running fine until it had a bearing issue and started knocking.
So I picked up a GM crate 350, new injectors, knock sensor, and ESC module.
At first I had issues getting to to fire and determined it was 180 degrees out of alignment. That was fixed and the backfiring stopped. At this point it would start to fire, but It would not catch and run. I insured cylinder one was a tdc and have checked the wires multiple times. I have tried to adjust the timing a little and it sounds like it wants to start but just won't.
Since then I have replaced the fuel pump , pump relay, and fuel filter (although I can see fuel coming out of the injectors, and hear the pump priming when I turn the ignition on). I have also ordered a pressure gauge and fitting for the filter to confirm actual fuel pressure.
I have also replaced the entire distributor with a new AC Delco oem replacement. The old one was rather rusted and the contact didn't seem great. I was concerned the pickup or sensor was bad and not sending the injector pulses.
This didn't seem to have any effect so I ordered myself a code reader to see if I could pull any helpful info off the computer to help get me on the right track. Unfortunately it spit out 10 codes at me and did nothing to help me narrow down my issue.
The code reader gave the the following codes.
42
35
33
32
31
55
54
52
51
43
After seeing these the ECM seemed to be a fairly common thing amongst the codes. I double checked my grounds and decided to order a replacement AC delco oem ECM. After putting the prom and memcal in the new ECM I checked the grounding and wiring one last time before hooking the battery back up.
The truck is a plow truck and the previous owner did the install and hacked the wiring up a little. Befor hooking the battery back up
I noticed I had been hooking a grounding cable directly to the positive terminal (the truck has a standard neg cable terminal and multiple additional
Wires on a threaded negative terminal, with only three wires on the threaded terminal on the positive side and no standard battery cable terminal). It has a brand new marine/rv battery.
I corrected the incorrect ground cable routing prior to trying to start on the new ECM. The truck did the same thing and seemed to throw out the same exact ten error codes afterwards.
There are multiple other supporting features nf items that were cleaned and or replaced but nothing that I can think of that would cause this. Has a new radiator and water pump, torque converter, an edelbrock manifold, I cleaned the tbi unit and rebuilt the fpr. I have a new set of headers but have reinstalled the factory manifolds and am trying to start it open header with the factory 02 sensor installed. All of the factory smog equipment was retained.
I don't know what I am missing.
42
35
33
32
31
55
54
52
51
43
