FightinTXag
I bought an '87 2wd Burb with a strong running TBI 350 with about 10k mi since rebuild for $1800. My plan is to take the recently rebuilt 350 along with all of the TBI and swap it all into my '85 K10. If I can get a couple hundred for the motorless beast when I'm through, I'll have a recently rebuilt TBI 350 for not much more than a long block +core charge. Plus I'll have the convenience of taking my time with the donor sitting right next to my truck and the peace of mind knowing I've got everything I need and every piece is in good working order.
So I started by pulling my tired old 305 with the shot rear main seal, the bad valve guides/seals, and the Q-jet/ESC HEI combo that seemed to run differently everyday. I'll probably spend most of the rest of the week cleaning up my engine bay.
I think my plan of attack now is to then pull the motor from the Sub. As I disconnect everything I'm going to label it carefully. Then with the engines out of both trucks, I'm going to take my time transferring the wiring and plumbing the fuel lines. I figure it'll be easier to route everything if I can crawl in the engine bay without the motor being in the way.
I plan to go with an inline external pump unless I can get a good deal on a tank with sending unit & pump from a SWB '87 at Pick 'n Pull.
My '85 came with cruise so VSS should be there on the speedo same as the '87 Burb. Since both VSS are on the speedo, I shouldn't have any problem with pulse per minute discrepancy if I keep my cluster. Right?
I'm going to look at swapping out everything including the cluster (I'll have to put my clock on the Sub's panel if I go this route), but I'm not opposed to making a couple of splices if that is simpler than swapping out a bunch of in-cab wiring. Thoughts?
Anything else I should be considering? Is there any reason to wait until the motor is in place before tackling the wiring or fuel lines?
Also, is it ok to lift the TBI 350 using one of those carb plate hook things? I know the intake manifold is aluminum and I don't want to crack it or strip the screws on that thing.
But having a diesel harness before, I noticed there were a fair number of extra connectors that similar year gas ones didn't have.
