87 TBI no fuel...
Did a bit more research and was told to look for a fuse link going to the fuel pump relay and to check and see if it id getting power at all times to the a terminal. Now I am really lost. There is no fuse link comming from starter to the relay it just say fuselink on the wire and i am not getting power.
The wire thay says "fuselink" IS the fuseable link wire and you have no power because it is bad.
Regardless of the fusible link being blown, I thought you hotwired the fuel pump with no results. You said you had pressure but nothing coming out of the injectors...
On my truck, it was the fuel pump. They didn't stock the Bosch pump and I wasn't waiting a day for it. Put in another Airtex and it is MUCH quieter than the last one even when it was new last year. They even warrantied the strainer and gave me a new one no charge. I didn't even ask, they just did it. So, I bought a new fuel filter and put that in too. Happy with Advance Auto Parts right now, although, I never really had an issue with them before anyways.
