Kevin Strident
Registered Member
This is a very old problem that I've ignored for some time but since the truck has again become my DD, I'd like to have it running as well as it can.
33 - map sensor out of range, high
43 - knock sensor or electronic spark control circuit fault
45 - oxygen sensor, rich exhaust
All of these codes are probably accurate but I've wasted a lot of money over the years throwing sensors at problems that were caused by other things. The map sensor has probably been replaced at some point. The ESP is an eBay part from many years ago. The O2 sensor is ancient as well.
Is there anything to troubleshoot with these codes or this particular combination or should I just hit RockAuto and spend the $120 to replace this junk?
