GonicGM
Recently acquired 87 V3500 Dually Standard cab with SM465, stock BBC TBI. Paperwork supplied indicates new GM Goodwrench motor in 1998, warrantied by GM Dealer in 2001 for cold temperature noise. Receipts indicated bored & new pistons. It may be a 462 at this point. Regardless, it has just a few thousand miles since. It starts up easily with zero engine noise. I figure I have a solid motor. It's a heavy truck, but I believe it could demonstrate better performance without the sacrifice of economy. I plan to verify basics for baseline function, vacuum leaks, EGR valve and solenoid function, MAP sensor function, IAC function, TPS function, static timing, temperature sender.
From there, I'm considering headers, better flowing exhaust, heated O2, 454 TBI Edelbrock, flow matched injectors.
Any feedback on what works, what doesn't, what I haven't considered.
