Thats about the rpm where the EGR valve would open,if its still there and connected..check that to see if its sticking or opening too early..
Also check the vacuum advance if it has one,it could be failing,or perhaps the centrifical weights in the distributor have a lot of wear on the pins they ride on and is making the advance erratic..could also be the pick up coil wires are broken inside and making partial contact..
But since its a Holley,it could just be a fluke in the carb..I hated almost every one I had,with few exceptions..could never keep them working right one day to the next..power valves blew if it spit back in the morning when I opened the choke too soon,floats liked to drop or go out of adjustment for no good reason,etc..I put the Q-jet back on or got an AFB Carter or Edelbrock,they ran sweet on the street..not so great off road without mods though..
