k5floyd
my 88 k5 sat in my driveway for about 3 and a half years after rebuilding the transmission. it ran great before sitting.
i replaced all the vaccum lines, put a brand new battery in it, new fuel filter, drained all but a few gallons of gas and put 20 fresh gallons in it.
it started right up and idled great everything sounded good. couple days later started it up to let it warm up a bit before i changed the oil. well it ran fine for a couple minutes and then just randomly died. tried to start it back up and it started up for a couple seconds and then died. did the same thing everytime after that.
got my step bro to start it as i tried to keep it running with starting fluid but same thing kept happening. i could see the injectors spraying fuel and i can hear the fuel pump turn on when i turn the key forward. so im thinking its got to be an ignition issue. checked all the fuses, they were good.
then i pulled the distributor cap and everything was rusted and corroded so i replaced the cap and rotor and the icm and cleaned the rust off the reluctor(?) with a wire brush. tried to start it up and same thing. and now it just fires up for a split second and does not really start up.
i have tried two different spare coils, a spare msd ignition box, brand new map sensor, spare fuel pump relay, and i have unplugged just about every sensor one at a time, and still same thing, it fires for a split second and dies. the fuses are all still good.
anyone have any ideas or know what else i can do?? thanks
