First timer here. I have a 88 blazer 5.7 tbi. Was driving the other day and idle came up after putting seafoam in tank. Pulled in driveway shut off went back out 10 mins later to pull in garage it started fine went to back up it died. All it would do is click, jumped starter to make sure it wasn't locked up, Found a loose wire on starter fixed that. Now it Turns over fine but no fire. I have put new ignition module, new coil, new plugs. I checked spark at plugs I have that. I have checked to make sure I'm getting fuel. I have checked TDC to make sure the timing didn't change. As far as I can tell timing is still on. I have also test light the wire out of the coil to make sure they are sending signal from distributor to coil. I'm at a complete
Loss on what this could be.
