bumpass1
Newbie
New to the forum and in need os some help. I have an "88 C2500 that is running horrible. When cold I can start it up fairly easy, but it will idle rough. Once it warms up a bit it will idle better, but when you just touch the throttle it will die. Once she dies I have to floor it to get it to refire. If you punch the throttle when running it will rev up and sound halfway decent. When it will idle decently, the motor bogs down and dies when you put it in gear. So far I have changed the plugs, cap, and rotor, coil, ignition module, fuel filter, idle air control valve, and the throttle body gasket. It is not throwing any codes and I am at a loss as to what to look for at this point.
Any Ideas??
Thanks for the advice.
Jamie
Any Ideas??
Jamie
