88 camaro relay placement?
Sorry I don't know exactly where. This is all the 84 manual says.
If it's got the audible warning, it may be located in a "convenience center" which may also house the hazard flasher, door chime buzzer, etc. In the trucks it's over the gas pedal.
Not sure they'd use a relay, probably didn't need one since there would be very little load on the circuit. If the alarm for key in ignition/headlights on, I'd probably suspect something else.
I have the '88 Camaro service manual at home if you need me to check and see if I can find anything additional.
i know on some chevy cars from the 80's and earily 90's, they put a body control mod. in the kick panel on the front passenger side. dont know if this is what your looking for or not but its a place to check, i know they gave me problems in the shop.
Plan is to borrow the module to control the airbag control light in another car that needs to pass yearly inspection.
i know on my corsica, beretta, and cavaliers, the pice your looking for should be what i described above. i would imagine the camaro would be in the same place
im prety sure they all use the same unit too.
