If the coolant temp sensor is open or shorted, it will cause the truck to run very rich.
If the fuel flow/pressure is low, it will be running very lean. If lean (low fuel pressure) is the condition, then while it is idling try spraying a little carb cleaner into the throttle body while holding the rpms at about 1500 (if it will).
If it runs better, than this will indicate that a lean condition (not enough fuel) exists. Check the injector spray pattern while the engine is at idle. They should both look similar and not be gobbing large amounts of fuel into the engine.
A vacuum leak is a possibility as well. At idle, spray carb cleaner around the intake manifold and see if the rpms change. Dont let any enter the TB or this will skew your results
This is just a few things you can check quickly and are not related to the ignition system....
Which codes exactly? Code 12 is normal, but you should only get that one. Any other code is indicating a real problem. Not necessarily with that item, just that item is out of spec for whatever reason. For example, code may say "O2 lean", but the problem isn't the O2 sensor, (though it could be) but really low fuel pressure, bad injector, etc. A "low MAP voltage" code could be a loose wire at a connector, and so on. Which is why you can't throw parts at problems.
i had the parts and is was messed up. so i did it why i was there. the light still just flashes. i dont have the time this. just going to by some damn scanner and get this done .
